メインコンテンツにスキップ
Repair guides and support for computer monitors produced by Samsung.
White screen on a Samsung Syncmaster 950NW
Hello,
Sycmaster 940NW is recognised by laptops (even passes its serial number via VGA), but the display is completely white and OSD does not appear.
I have replaced a fuse and a diode bridge on the internal PSU (before that, the screen did not even switch on).
How do I troubleshoot further?
Thanks,
Vincent
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Hi @vincentdk
Here's the service manual for a Syncmaster 940NW that may help.
(Although you did also say 950NW - which is it?)
When you have downloaded and extracted all the files, open the file marked 740NW[7].pdf and then go to p.4-3 (3 of 8 pdf numbering) and follow the No video troubleshooting flowchart.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Hi @jayeff,
thanks for your reply. Unfortunately, this goes a bit beyond my skills ("Does X300 oscillate correctly?"). But I appreciate your concern.
Kind regards,
Vincent
さんによる
コメントを追加
回答を追加する
VincentDK さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 82
