メインコンテンツにスキップ
ロジクールMX Master 3Sワイヤレスマウスの修理・分解情報です。2022年に発売され、モデル番号MR0077、810-008295、または910-006556で識別されます。
Solid Red LED with no connection to the target
My MX Master 3S always has a solid red LED on it. After every power on and off, I can see a green LED come up. Below, I can see the mouse in pairing mode, and it appears on my laptop as well. But then, after 1 minute, it turns to solid red, and I cannot see it anymore on my laptop.
Could this be a loose connection? Or does it require a battery replacement? I have a 2S and 3, all of which show that they are charging by blinking LEDs in both mice, but for my 3S, it just shows a solid red even when it is being charged. I have already charged it for 3 hours, but the same behaviour.
I have already changed my dongle to the universal bolt
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
3 件のコメント
Thank you very much @jayeff for your reply.
A very stupid question, so I just take out the battery and check the voltage right away right? And it should be around 3.8V? It won't matter on the state of charge within the battery.
さんによる
@peekabooboo
You said that you have already charged it for 3 hours so after this amount of time it would be very close to being fully charged so the voltage should be at least 3.8V.
さんによる
Understood. Thank you.
I will check this and come back here just in case and follow the guide you have attached. Thank you very much
さんによる
コメントを追加
1 件の回答
最も参考になった回答
Hi @peekabooboo
If you have a DMM (digital multimeter) check the voltage of the battery in the mouse to see if it is OK or not i.e. approx 3.8V DC.
Here's the ifixit ロジクール MX Master 3 バッテリーの交換 guide that may help.
If the battery is faulty ifixit sells a battery for the mouse (see guide) or search online for 533-000205 to find suppliers that suit you best.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Hello,
I checked and it has 4.11V
さんによる
コメントを追加
回答を追加する
Peekabooboo さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 12
過去 30 日: 54
今までの合計 445
