メインコンテンツにスキップ
Nintendoのハンドヘルドデバイスは2011年2月に発売されました。モデル番号はCTR-001です。
My 3ds remains with a black screen on the home screen unless it is on
Hey folks, I have a old Nintendo 3DS that has two black screens, it turns on the other lights normally and the only thing that opens is the Luma3DS booth screen, however, it does not start the common start screen. Has anyone experienced this problem?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
4 件のコメント
@agatha40506 let's see if our console Guru @dan0 has a solution for you.
さんによる
I think it's software related! As it is modded, @darthmango knows more about this. Sorry!
さんによる
Sounds like RTCBug. @agatha40506 , are you able to access Rosalina (from the black screen) and GM9?
さんによる
さんによる
コメントを追加
1 件の回答
最も参考になった回答
RTCBug it is! The fix is pretty simple:
  1. Power off the console
  2. Take out any game cartridge, but leave the SD card in
    • The cartridge is unrelated to this issue, but could also cause issues with booting if it's not being read correctly
  3. Power on the console
  4. Leave the console open and powered on for 10-15 minutes. Do not touch the console during this time
If it boots by then, you're all set and shouldn't have to worry about this again.
(P.S. If you're a nerd like me who wants to know why and how this happens, you can find more info here: https://wiki.hacks.guide/wiki/3DS:RTC_bl...)
このアンサーは役に立ちましたか?
スコア 2
7 件のコメント:
I did this before and doesn't work for me, Is there any other solution? Do you think it could be something related to the hardware?
さんによる
@agatha40506 I don't see how it could be a hardware issue, since everything else seems to load normally. I'll have to do some research on this. In the meantime, see if you can also access safe mode. Using the 3DS's Safe Mode
さんによる
@agatha40506 Sorry this took so long! Let's try the Black screen unbrick page from the wiki. Start by checking that luma and gm9 are up to date; they should be v13.2.1 and v2.1.1 respectively. (If they aren't, update them and try the rtcbug fix again, just to be safe.)
Next, make a NAND backup (https://3ds.hacks.guide/godmode9-usage.h...), store it somewhere safe, and start from Section III - Luma3DS Configuration Reset. (https://wiki.hacks.guide/wiki/3DS:Black_...)
さんによる
I tried this one but it doesn't solve it, but thank you so much anyway. I really appreciate your help
さんによる
@agatha40506 That's... odd. Did you go down the rest of the page too?
さんによる
2件以上のコメントを表示
コメントを追加
回答を追加する
Agatha さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 22
今までの合計 207
