メインコンテンツにスキップ
ロジクールから発売されたワイヤレスRGBゲーミング用キーボード
Charging port broken it won't charge
How do I replace the charging port in my keyboard. I dropped the keyboard while it was plugged in and the middle piece inside the charging port was bent out of place and ever since then won't charge. I tried to move the inside peice back into its original place but that didn't work either.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
@christianr67270 sounds like you will have to do some soldering :-). First off, take some good pictures of your damaged port. It could be Micro-USB or a Type-C port. Next, you will need to disassemble your keyboard. Also not a guide, this teardown should be helpful for that. Once you have to bottom removed, take another couple of good pictures of where the port is located. That way we can see if the traces etc. are still good. Once you have all that, it'll be time to find a replacement. Mouser or Digikey are usually my go-to for parts like that. Only issue is that you will have to search by dimensions since your port will not have a part number etc. Ultimately you'll have to disassemble your keyboard, desolder old connector, resolder new connector :-)
iFixitでの質問に画像を追加する方法
iFixitの画像
ガイド
難易度:
とても簡単
2 - 5 minutes
Logitech G915 Wireless (Clicky)の画像
ガイド
Logitech G915 TKL Wireless (Tactile) Teardown
難易度:
中レベル
30 minutes
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Christian Rodriguez さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 7
過去 30 日: 43
今までの合計 427
