メインコンテンツにスキップ
A2116 / 2019 / 3.6 GHz quad-core i3, 3.0 GHz 6-core i5, or 3.2 GHz 6-core i7 プロセッサ、発売日は2019年3月19日です。
How do I clone the hard drive?
I see in the comments that people forgot to clone their hard drive and had to take the Imac back apart. How do i clone the hard drive?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
I'm guessing you have a Fusion Drive and are planning to replace the drive, but I could be wrong. Either way, if the system is bootable, you could boot up and back up the system to an external drive via Time Machine. Otherwise, if the system isn't bootable, then to clone everything you would need another computer or a bootable external drive. If using another computer, you would put the iMac in target disk mode and connect it to the other computer, then on the other computer you would use a program like Carbon Copy Cloner to cloner the drive in the iMac to an external drive. If you're using a bootable external drive, you would connect that to the iMac, boot into it, then use Carbon Copy Cloner to clone the internal drive to an external drive. Good luck!
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Cloning is old school with much simpler file systems than we have today.
Stick with Apples tools using Time Machine to backup or use Migration Assistant via Target Disk Mode between the systems. Apple’s current file structure and security within the file system really makes using cloning impossible! Besides there’s a lot of old cache file data which you would be copying over wasting space on your new system.
さんによる
コメントを追加
回答を追加する
Bob Garcia さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 2
今までの合計 73
