pram battery MacBook mb991
MacBook Pro 13" Core 2 Duo Models mb991
hi.is there any pram battery in macbook pro mid2009?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
There is no replaceable PRAM battery in this model. This model uses a capacitor on the logic board to hold the PRAM settings.
このアンサーは役に立ちましたか?
No - the "regular" battery provides that function.
If this Answer is helpful please remember to return and mark it Accepted.
このアンサーは役に立ちましたか?
Yes, you need to unsolder it. It is located right next to the trackpad connector. It looks exactly like a small watch battery with solder tabs. Be very careful, too much heat and the logic board trace will lift.
"I am looking at a small battery soldered onto the A1278 logic board right now as I type. All macbooks and macbook pros have batteries, but most are on a pigtailed connector either taped to the logic board or hidden under the optical drive. The sizes range from a 1/4 dime to a quarter. The types are lithium although the smallest almost seem like alkalines?"
このアンサーは役に立ちましたか?
edited for spam
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 7,789
1件のコメント
Apple MacBook Pro "Core 2 Duo" 2.53 13" (SD/FW) Specs
Identifiers: Mid-2009 13" - MB991LL/A - MacBookPro5,5 - A1278 - 2326*
mayer さんによる
