メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Nintendoのハンドヘルドデバイスは2011年2月に発売されました。モデル番号はCTR-001です。
3ds XL only boots into recovery mode, no sound when it turns on
I tried to look everywhere for a way to fix this 3ds, I believe its a software issue but im not 100% sure. The 3DS doesnt seem to have CFW since I cant boot either to GM9 or Luma menu, and I think the 3ds is bricked somehow. I bought this online so I dont know its history, but I would appreciate if someone can guide me in the direction of a guide to unbrick a 3ds with these issues. Heres a video: https://youtube.com/shorts/TqxsZIedlFc?f...
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
4 件のコメント
Hi! Most of the time the firmware is corrupted. Can you post a video for us? Thanks!
さんによる
I edited the post and put a link to it
さんによる
コメントを追加
2件の回答
最も参考になった回答
Hi Juan!
Thanks for the video! It is semi bricked! Please try the following method: https://www.reddit.com/r/3DS/comments/ol...
Otherwise you need to check the EMMC on the motherboard! Replacing this should fix it, but is hard to do. You could also replace the motherboard, but this will be expensive.
このアンサーは役に立ちましたか?
スコア 2
6 件のコメント:
Thanks for the response.
So, I tried both the LRStart and the LRSelect and even all at the same time but it wouldnt to anything. Now im looking online for how to check the EMMC on the motherboard but I dont know how. I can probably replace it since I have experience soldering and I've been working on 3Ds for a while now, I just need to know how.
さんによる
Hi Juan!
Here you need to check Step 14: Nintendo 3DS Teardown
Please check the following IC: Toshiba THGBM2G3P1FBAI8 2 GB NAND Flash
You probably need to replace this one with a hot air station and place a new one on it. Not sure where you can find the part :(. Best thing to do is to find a donor (broken) motherboard with a different issues and get the NAND from there! This is difficult, but since you have experience, it should be doable!
Good luck and let us know how it goes :)!
さんによる
@dan0 Hey,
I recently purchased a "Parts/Repair" 2DSXL. I'm actually in the exact same boat as the OP and I'm starting to think taking that chip from another card might be the route I need to take. I think the most frustrating part is that the Recovery (L+R+UPdpad+A) works well and proves the Buttons/Screens/WiFi all work, but I guess it's just missing it's firmware(NAND)?
Thanks for your response
さんによる
Hi Dean! If you are able to get in through recovery, you might want to update the firmware/software and see how that goes :)! Otherwise you probably do need to replace the NAND...
さんによる
@dan0 Hey! Thanks for the response!
When I do the recovery, it just says that the system is up to date and then shuts off. Then, attempting to turn it on normally repeats the cycle of: Blue light, Black screens. Not even a backlight.
Also, I realized the guide picture you referenced was for the 3DS, and the 2DS has a different motherboard. I was curious if you have any sources to find a chip breakdown like the link you sent, but for the 2DS XL Motherboard? Or any way to identify the NAND chip on this console? I will be looking online for it as well.
Thanks!
さんによる
1以上のコメントを表示
コメントを追加
I just had this EXACT problem yesterday. My 3DS had never been hacked, and this happened randomly after powering it off and on. I stumbled upon your question in pursuit of answers. I kept searching, and I found a post on gbatemp where this “soft brick” was described. In my case, it was was the “gamecoin” brick. I had to hack my 3DS to remove a corrupted file, and then it worked perfectly again. I hope this helps fix yours. Good luck.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
How did you hack your 3DS without being able to access the main menu
さんによる
コメントを追加
回答を追加する
Juan Parra さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 7
今までの合計 237
