メインコンテンツにスキップ
Honda Pilot, Is a lineup of large SUVs. Quite reliable, Fun to drive
Why radiator mix oil and water
car engine temperature high
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
@watban most common cause is a damaged cylinder head gasket. This allow oil and water to mix and can also be the cause for the overheating. I suggest that you stop driving your Honda since you may end up with further damage.
Replacing a cylinder head gasket (or even a cracked cylinder head) is pretty involved and if you have never done this, you could consider some help from a mechanic, shop etc.
For a more specific breakdown and how to replace it, we would need to know the exact year and engine size for your Honda.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
watban さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 4
今までの合計 45
