メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2001年に発売された任天堂ゲームボーイアドバンス。修理は一般的なツールがあれば対応できます。
Well well I somehow messed up my funny playing screen :(
I installed a funny playing ips screen and battery along with an led board. Everything was working flawlessly except my select button wasn't working. I took the wire off the select button for the screen and tried it but now my screens backlight doesn't work. I realized that I got a bad pad on my select so I replaced it with the original. The select button works now but my screen will not light up. The game plays, everything works but my screen now. I've reattached the ribbon cables and touch pad 4 times now and nothing new.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hi Blake!
Usually this is caused by a faulty ribbon cable, and so the ribbon cable need to be replaced to get this fixed.
Please replace the ribbon cable first.
Good luck with the repair and please let us know how it goes!
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
But my screen was working fine before I opened it back up, so how is the ribbon bad now with it was just working? The screen still works just not the backlight
さんによる
Can you make some pictures for us? Inside the gameboy and also the select pad? A faulty ribbon cable can cause blacklight issues..
さんによる
コメントを追加
回答を追加する
Blake B さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 27
今までの合計 231
