Reboot and select proper boot device or insert boot media
画像の内容を見る:
この質問は役に立ちましたか?
thanks @oldturkey03 but i just went to the bios did the restore defaults and its good now and i am typing from my pc now i think i used my tv as monitor and then back to my monitor and then tv and then montior thats why smthing happend i have a r7 5700x and a gtx1650 and 6 gb ram unfortunately which doesnt run games on more than 30 fps so i will buy it on my birthjday next month on 19 and thanks for suggesting thoo ✌
このアンサーは役に立ちましたか?
@atharvpandey perfect. glad you got it fixed. Something must have changed your default and I guess sometimes that happens.
yea thanks @oldturkey03
@atharvpandey your computer does not find the OS to boot from. This is most commonly caused by a failed boot drive (either HDD or SSD). Since you did not tell us what computer you have, we can only suggest to check the BIOS to see if that still finds your boot drive. Another quick check would be to change the boot order in the BIOS to USB drive. Then get a bootable USB driver and see if your computer works with that. If so, you know you have most likely a failed drive.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 8
過去 30 日: 58
今までの合計 459
