Why is my camera saying can't connect to camera
@aluwanif could be a bad camera module or a bad 3rd party app. Start your phone is safe mode and see if your camera works in that. If so, you know that you have a bad app. delete your downloaded apps until you find the one that is causing this.
If it does not work in safe mode it is likely your camera module. you may have to consider replacing it. Let us know what you find out.
To place your phone in safe mode when the phone is turned on, long press the volume down key to enter the safe mode. After entering the safe mode, the word "safe mode" will appear in the lower left corner of the phone screen.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 6
過去 30 日: 6
今までの合計 6
