メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Repair and disassembly information for Samsung's Galaxy A32 5G Android smartphone, released in February of 2021.
Why does my phone display broken cable while shut down and charging?
When I plug in my phone when it is powered off it displays a blue screen with the message broken cable. The message goes away after a while and the phone starts charging, but this issue is in the way of solving another, bigger, issue. the message does not happen when the phone is powered on and it displays with all chargers. Is there a way to fix this?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
最も参考になった回答
@jeanjballard
With a USB cable there are not just plus and minus power wires, but also data communication wires. I assume the phone is trying to talk to the charger but can't for some reason, giving you the silly "broken cable" message. In most cases it's probably true; the constant flexing of the cable does tend to break wires inside over time, but obviously not every charger you have has broken wires.
In that case we have to assume it's something inside the phone not letting it talk to the charger. The first and most obvious choice is the charging port itself. It's susceptible to wear from being plugged and unplugged daily, it can get dirt and lint lodged inside preventing a connection, and the pins inside can get bent and broken.
So if you've already cleaned the port and checked it for damaged pins, then the first step in fixing the problem is to replace the charging port. On Samsung phones its located on a small daughter card at the bottom of the phone that inexpensive and relatively easy to replace, as phone repairs go. I didn't find any iFixit-style written guides to that repair for you, but I did go through a couple of YouTube videos till I found one that looks complete and instructive.
Samsung Galaxy A32 5G Charging Port Replacement - No Soldering Needed - YouTube
If replacing the charging port doesn't fix the issue, you could try replacing the flex cable that connects the daughter card to the motherboard. If neither one helps, then it would have to be something wrong with the motherboard, which would require specialized expertise and equipment to repair.
Hopefully it's just the charging port and that gets your phone up and running like new again!
And as you work, take lots of pictures and once you're done you can use them to create your very own iFixit guide to charging port replacement on your Samsung Galaxy A32 5G. It's easy, fun, and will earn you the gratitude of the repair community.
Create a new Guide - iFixit
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
This happened to me when my phone battery ran down to zero. I got that message when it was plugged into a USB-c outlet. When I changed cable to a USB 3.0 outlet it charged fine. On changing back to USB-c I got the message again. It only went off when the charge had passed 2%. This is a Samsung glitch that needs solving but at least there are work arounds.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
This happened to me after my phone went to zero power. I plugged it into the charger and let charge an ample time. When I tried to use it, that's when it said broken cable and would not work. I have had no luck getting it to start up again. I have used different chargers, but no luck.
さんによる
コメントを追加
回答を追加する
Benjamin さん、ありがとうございました!
統計データ:
過去 24時間: 4
過去 7 日: 40
過去 30 日: 161
今までの合計 2,407
