1.83、2.0、2.1、 2.16、2.2、または2.4 GHzのいずれかのCore 2 Duoプロセッサーを搭載したModel A1181
1468の回答 すべて表示
Black screen: Inverter, Cable, Display or Logicboard?
Hi!
Please help me!
My screen kept turning black if i tilted it, so i replaced the inverter cable. It worked but only in the low light area (1-2 bars). It stopped to work after a while and the screen didnt turn on at all. So i replaced the inverter, which didnt help. I would like to know if there is a sure way to find out if there is a problem with the inverter, the inverter cable, display or logicboard.
Any help would be appriciated.
Thanks in Advance
Maxim
回答がありました! View the answer 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメント:
It was a bad screen. I ordered a new one and everything is fine now!
による
コメントを追加
Pro Tech ツールキットを含むご注文、もしくは総額 $100ドル以上のご注文については送料無料です。
当社のショップを閲覧する
3回答
選択されたソリューション
If your model is the A1181, there is no soldering in the repair. Here's the guide with video on doing it: MacBook Core 2 Duo LCD Panel Replacement
この回答は役に立ちましたか?
スコア 5
コメント:
Thank you, i knew. I was talking about replacing only the lamp in the panel.
による
I wouldn't blame Maxim: if there's a level beyond "difficoult", the refurbishment of an LCD panel looks like that.
Furthemore, if one want to be a cheapskate, while new panels have dropped in price in the last years, used ones get to be sold at half price.
による
コメントを追加
There's no surefire way, I'm afraid to tell you.
However, a damage on the logicboard would mean a damage on the capacitors near the inverter cable, and that's a really, really rare occurence.
The usual troubleshooting for your issue implies:
  1. Replacing the inverter cable: it usually does the trick if the backlight goes on and off when the display is tilted
  2. Replacing the inverter, who's usually the culprit for a dim or flickering light
  3. Replacing the display.
You told that the light worked only in the "low part" of the display. Was it also dim, and affected by a pinkish/yellowish hue, lacking luster?
Your kind of display gets its light source by a CCFL Lamp, something that, for a visual reference, looks like a very thin, stretched neon, lodged in the low area of the display, hidden by a reflective foil that reflects the light evenly.
Thus, despite no one can be absolutely sure that you've not got capacitor issues, I'd try going for a display repair.
Afterall, the CCFL have a shelf life shorter than the rest of the laptop.
I'd telly you to go for a full LCD panel replacement: good refurbished panels are half the price of new ones, and new ones are still less expensive than a logic board.
You could also replace the lamp only, but no one goes that: it's a painstalking work of peeling off the reflective foil, avoiding to crimple it, desoldering the CCFL lamp, soldering back a new one and hope to have done nothing wrong.
この回答は役に立ちましたか?
スコア 3
コメント:
Thank you very much. It was really helpfull. By "low light area" i ment the first two bars of bars of brightness adjustment. Since i already replaced the cable and the inverter i have to replace the screen, and since i am really bad at soldering i will buy a whole panel. I have one more quastion: what do you think could be the reason for the display working ONLY with low brightness? Could it be an avidence for the bad capacitors? Can i test them with a multimeter somehow to be sure?
Thank you for your help.
による
In my life, I've never seen a case of bad capacitors. That's a really, really rare occurrence. I know you can test with a multimeter the Inverter, so you could try to see if there's current in the inverter cable.
A display shutting down at its maximum setting, AFAIK, shows Inverter or CCFL issues.
As I told you, besides using a multimeter to check carefully what comes out the Inverter Cable and the Inverter, there's no other troubleshooting to do.
による
Thank you very very much!
による
I can only add my personal experience: my own LCD flickered badly. Not the kind of "refresh" you may see when you're working late and your eyes burn, but when I was at max brightness to max minus 3 bars, it literally strobed.
After a change of Inverter and LCD, it got fine. I hope that'll solve your issue too.
However, recheck the Inverter, if you've not bought it by a reputable source. Some used inverters tend to be DOA...that is, malfunctioning on arrival.
による
コメントを追加
I got the exact problem.
I tryed changing the inverter without success, then I tryed to changing the inverter cable no success. If the brigthness il set to max (16/16) the screen go black after few seconds, if setted to 7/16 bars the screen works whit random blackout, if I increase one bar (8/16) works for few seconds then go black again.
I just ordered a new inverter, hoping that the refurbished one I bought was broken.
when the screen go black, to turn it on again I have to set brightness down to zero (0/16) (F1) and then increase (F2).
I need some advice.
Do I need to replace the LCD Screen?
Cris
(sorry for my English ^_-)
この回答は役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Maxim Proleskovski さん、ありがとうございました!
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 2,366
