メインコンテンツにスキップ
Released August 2003. An expensive, but high-end laptop of its time.
Why won't it boot up
press on button. green light comes on, screen flashes (sometimes) then it's dead
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア -1
2 件のコメント
Anything happen to it? Do you get any sign of the POST? What have you tired so far to fix it? Have your tried an AC adapter?
さんによる
i'm back on with the machine in question maybe graphics card? don't know alot, is there some diagnostics i could run through it?
さんによる
コメントを追加
1 件の回答
最も参考になった回答
henge, you might want to check on here. Those Dells' are prone to failure, especially the hard drive. Check your RAM as well. Good Luck.
このアンサーは役に立ちましたか?
スコア 3
4 件のコメント:
came on after many attempts a month ago getting less reliable in switching on, runs great when its going but now it wont start. battery seems fine. thanks for takin the time.
さんによる
Do any of your LED's come on or do they blink? Have you tried an external monitor to make sure that it is not just your LCD?
さんによる
Here is the service manual for your computer http://www.elhvb.com/mobokive/edwin/lapt...
さんによる
thanks for trying old turkey, I'll let it hibernate through summer and look for another.
さんによる
コメントを追加
回答を追加する
henge さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 12
今までの合計 1,335
