メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2020年5月に発表・発売されたマイクロソフトのWindowsタブレットSurface Go 2 の修理・分解情報です。
replacing the battery on the MS Go 2 10.5"
Hello,
I was contemplating replacing the battery and wondered what is required to do that. Is it possible to do it if I just have the right screws? Any extra info would be appreciated.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Unfortunately, Microsoft surfaces are terrible for reparability. It is designed never to be opened again. they are so terribly built that if you open it and attempt a repair, you are very likely to ruin something, especially if it is the first time you have fixed something. It is not easy to disconnect the battery when you first open the surface, so just by unscrewing things, if you just tap a wrong spot, it could kill the surface. To make things worse, if opening the surface requires peeling the screen off, which can easily crack it.
If I were you, I would use it as it is, unless it is really bothering you. I hope this helps. Please let me know if it does answer any of your questions.
Falcon16
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
He's got a Point, for Surface Pro.
The Go Line-up is really easy to open, since the adhesive is not that strong.
Second, direct after opening you can directly disconnect the battery.
the battery itself however is heavily glued into place and needs a good amount of heat and force to get it out.
さんによる
コメントを追加
回答を追加する
Chantal Carnes さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 14
過去 30 日: 67
今までの合計 1,618
