メインコンテンツにスキップ
2.2 GHz (Turbo Boost使用時最大3.4 GHz), 2.5 GHz (Turbo Boost使用時最大3.7 GHz)もしくは2.8 GHz (Turbo Boost使用時最大4.0 GHz) L3キャッシュで6 MBのクアッドコアIntel Core i7プロセッサ
778回答 すべてを表示
Keys Not Working Correctly
A while back, my left shift key stopped working. It feels like it's slightly pressed down and won't fully bounce back up. Regardless of how many times I press the key, the shift function does not work.
Recently my left "a" "s" and "option/alt" keys are intermittently not working correctly. I need to hit the key a few times to get the letter to show up, often resulting in repeated letters: "aaaa". The "option" key is starting to act like the shift key and feels like it's not fully bouncing back up.
I haven't spilled anything on it, but my battery does need replacing. I read that the battery going bad is a possibility, but the battery isn't swollen or anything. I haven't gotten to it yet because I use my laptop almost 24/7 and don't really have the time to swop it out and have something potentially go wrong. But the keys not working is a real nuisance. I pried off the shift key to see if there was anything blocking it, just some dust, so I cleaned it, and put the key back, but it is still not working. Any ideas besides dust that could cause the keys to intermittently not work?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
It is almost a 10 year old model, things do wear out in time, the keys that have stopped working are in the most used catagory so it is likely that a keyboard replacement is in order, there are good guides on here on how to do that yourself, just needs some patience and a little courage and anyone can do this :) The Batteries are quite easy to change. 2015's are great Macs and some would argue they are amongst the best models apple ever made, I am using one myself!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Dorothy Phillips さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 16
今までの合計 16
