"No Batteries Available" displayed in upper corner of screen
My 2.4ghz macbook had the dreaded X intermittently appear in the battery icon in the upper right corner of the screen, and the dropdown would read "no batteries available." This would be the case even with a good battery in the computer. If unplugged, the computer would often run for a minute or two before abruptly shutting down. Gradually, this went from an occasional occurrence to the status quo.
この質問は役に立ちましたか?
1件のコメント
hi Bradford, if you wouldn't mind editing this a little then it would be even more helpful. Because you haven't supplied an answer in the "answers" part of the page, this question will be archived in 2 weeks as "unanswerable" and all your hard work will disappear! If you edit this at the 3rd paragraph and put the last 3 paragraphs as an answer then hey presto! this will be here forever and people can upvote if it's helpful. Don't forget to accept your answer as a solution too! Thanks for sharing, glad you solved the problem.
pollytintop さんによる
