メインコンテンツにスキップ
2018年7月に発売された15インチMacBook Proです。モデル番号はA1989です。15.4インチ LED-Backlightディスプレイ、True Toneテクノロジ、TouchIDと最大6 Core i9プロセッサを搭載しています。
210回答 すべてを表示
Trackpad sometimes doesnt work
Device name- macbook pro 2018 (model A1990).
My trackpad sometimes doesn't work. As example, everything works fine from the boot-up/starting when it works. it works fine for days. Then i shut down my macbook and restart after several hours. Trackpad stops working from the boot-up/starting, cursor, haptic, secondary click, nothing works.
Sometimes SMC reset fixes the issue (not everytime). I have already tried NVRAM/PRAM reset also, doesnt help. Tried diagnostic too, no issue found.
Again if i shut down now then trackpad may work again in next boot-up.
What may cause the issue?
Thanks and Regards
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
in most cases that would be either a punctured cable or it is a bit out from its connector on trackpad side. If you see and dents on trackpad cable, replace it using local guide
このアンサーは役に立ちましたか?
スコア 0
10 件のコメント:
Is there any chance that it may happen because of keyboard? In this model Trackpad and keyboard are different unit and connected to motherboard with separate flex.
さんによる
No/very unlikely. Keyboard dataline is routed directly to trackpad which controls both devices and them returns them to T2 as one device. Did you inspect the cable and its connection on trackpad side?
さんによる
I have changed the flex and found that flex is fine. i used my old flex with a good trackpad and everything works fine, so my trackpad flex was fine. Everything works fine only when i replace the trackpad. during these process trackpad flex got damaged and now keyboard also not working. If i use good trackpad flex with my old trackpad (broken) then keyboard only works, trackpad doesnt work as before. That means there is some connection between trackpad and keyboard. there should be some dataline between trackpad and keybaord although they are different unit and connected separately to motherboard.
さんによる
A swollen battery may push against the track pad and be a possible cause in case that hasn't been noticed.
さんによる
@reyazulzannat keyboard decoder is connected to trackpad, dataline is bridged through logicboard. as i mentioned, trackpad has stm32 controller which acts as both keyboard and trackpad devices. you need known good parts to troubleshoot. you can use A1707 trackpad / cable to diagnose, howewer cable is slightly different and wont fit.
さんによる
5件以上のコメントを表示
コメントを追加
回答を追加する
REYAZUL ZANNAT ANIK さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 24
今までの合計 56
