Can you test the ear speaker without service?
I recently replaced my ear speaker for iPhone 4 at&t but do NOT have service or a working sim card to make a test call... Is it possible to test the speaker another way?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Use stock iPhone App called Voice Memos. Make a 15-20 second memo. Then play the memo, tapping the Speaker button you can test the Earpiece Speaker.
このアンサーは役に立ちましたか?
thanks! good info
thanks,, it was helpful
get a Tango ,skype or Viber or any slimier app and try to call your friend who has the same app and you should be able to talk to your friend
note : you need an internet connection to do that
このアンサーは役に立ちましたか?
Another solution: Voice Control on the iPhone 4. Even without a SIM or AT&T service, if you say something into the microphone, the voice will respond through the earpiece to say "no match found" or another message. Hold the home button down until the Voice Control screen appears and then say a command.
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 21
過去 30 日: 63
今までの合計 100,040
2 件のコメント
easier test ... use dictafoon to record something and play it, it plays standard from the ear speaker
svenverhaegen さんによる
Actually, you can use the stock voice memo app to test the earpiece. Just turn off the speakerphone.
E West さんによる
