Why won't the proximity sensor respond?
I have replaced the screen on a black iphone 4. Normally if the sensor stops working, it is because the new screen is a light colored one like pink. This one is black but since the sensor isn't responding, I bought one of those sticker pads to put over the sensor. Still not working. I used a permanent marker on the back of the screen where the light shines through. Same result. Restored the phone to 5.1 and wiped out everything. Still the same. Bought a new sensor. Still not working. Went out and bought ANOTHER screen. Same thing.
So frustrating especially since they won't update that CallLock tweak so it is compatible with ios5. Anyone able to help?
この質問は役に立ちましたか?
I am having the exact same issue and have tried every solution listed in your posting and still can't find a solution.. I can assume you have read this to but if you have a screen protector on your phone try removing it.
john さんによる
Yea, I removed the plastic on both screens. Thought the solutions here looked promising but so far, no: https://discussions.apple.com/message/15...
Abraham Yosief さんによる
