iPod won't turn on or off?
My iPod's screen is frozen. It won't turn on/off or anything what could be the problem/solution?
Press and hold the middle button and the menu button at the same time. This should perform a hard reset and unfreeze the device.
このアンサーは役に立ちましたか?
My iPod has had similar issues in the past, in which even a hard reset would not work. If that is your case, just let it drain itself dead and then charge it back up. You should be good to go then!
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 2
過去 30 日: 8
今までの合計 2,247
1件のコメント
Is the little switch on the top in the "Lock" possition?
Chris Green さんによる
