Hi @danielpears9214
Here's the tech sheet for the model that will help.
Run service diagnostic mode Test #36 (Ice box fan) and Test # 37 (Ice box thermistor) as described by the guide and check if they are both OK.
If either one is not OK if you have a DMM (digital multimeter) you can check if they're getting power OK from the control board - see voltage table on p.2 for connector pin location on plug connector P8
Also verify that the lights turn off in the refrigerator compartment by manually operating the door switch with the door open, to simulate that the door is closed. The ice maker won't work if the control board thinks that the door is open and the only way it knows this is via the door switch. If the lights do turn off, then it still could be a faulty switch however, so you may have to test it electrically to know for sure.
If a part is faulty and needs to be replaced, here's a parts list that is useful.
When you have located the wanted part in the parts diagrams you'll find that the manufacturer's part number is listed with the part. Search online for the part number to find suppliers that suit you best.
