メインコンテンツにスキップ
Repair information for the 7" Android tablet by Samsung. Fixing this device is straightforward, and requires only common tools. The Samsung Galaxy Tab is an Android-based tablet computer produced by Samsung. The 7-inch Samsung Galaxy Tab is the first model in the series. It was introduced on September 2, 2010
112回答 すべてを表示
upgrade the item for better speed
well i'm french (vocabulary not good ) , i try to find a way to accelerate , if possible , the tab. as the computer , you can change the Rams for example . Is there anything to do for accelerate the tab ?
thanks for yours answers , i've already bought , in your E-shop , few screws for install a new battery as your guide showed it !!!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
ベストアンサー
First: this is an open space, not affiliated to iFixit, where happy customers help other happy customers. Thus, you should thank them, not us.
About your issues, a tablet is not a PC. Thus, expanding it it's a tricky business, and often the logic board is all well soldered.
Your unit is the Tab GT p1000, am I right? If it's that, it has the microSD slot.
One of the things you could to help is getting a fast microSD from a reputable and verifiable source. On my devices, I use Verbatim, Kingstone, Patriot and Sony, for example, and I never got misled.
Another thing that may help, but just a notch because a proper installation of Android is already equipped for that, is using a Task Killer and kill off periodically unwanted apps.
Then, be careful with widgets. To be snazzy and look smart around friends, I used to keep lots of widgets on my no-brand tablet. And I mean, six different iterations of the same clock widget just to know what time is it in Russia, Australia, Japan, Central Europe, New York and Jerusalem, Everynote, LauncherEX appointment manager even if I use a custom legal agenda and stuff.
When I decided to act as a reasonable man, all started to get better.
That's all that I can say about your issue: a more through job looks impossible, or needing a mindboggling level of expertise.
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
回答を追加する
yannicklafargue さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 2,211
