メインコンテンツにスキップ
Repair information and troubleshooting for Craftsman-brand riding lawnmowers.
How to put belt on the mower deck
how dose the belt go on the mower deck
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 7
7 件のコメント
how to put blade belt on modile 917289031.
さんによる
What about 3 belt craftsman.I have 2 ride mowers one is 2 belt other is 3belt ?? The deck belt patterns are different
さんによる
is this for a deck on a 7000 series 42" cut mower?
さんによる
This is. For the 2ooo series. Model 247.288852. Serial # 1A192B10186
さんによる
46 inch deck
さんによる
2件以上のコメントを表示
コメントを追加
1 件の回答
最も参考になった回答
Mike,
Usually there are two belts. One goes around two pulleys, a front pulley under the motor and one on the mower deck. Additionally, there is usually a spring tensioner pulley that rides against the belt to allow it to work and for ease of routing.
The second belt goes under the first belt and is routed on a common pulley with the drive belt and both (or all three) of the mower blade pulleys.
Here is a crazy looking exploded view of a craftsman mower deck
And here is a better diagram of it all put together. I think you can get an idea of belt routing out of this one:
このアンサーは役に立ちましたか?
スコア 3
2 件のコメント:
Do I have to bend the metal bracket that keeps belt from slipping off pulley to put a new belt on. The belt will not go on pulley unless I do bend it back.
さんによる
The bracket that holds the blade belt on the pulley is stable and will not move. How do I get the belt on pulley without bending it
さんによる
コメントを追加
回答を追加する
mike さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 5
過去 30 日: 55
今までの合計 67,823
