メインコンテンツにスキップ
日本国内では2017年7月13日に発売されたNintendo 2DSの後継モデルのハンドヘルドゲームコンソールです。海外では「New Nintendo 2DS XL」として販売されています。
20回答 すべてを表示
Ds doesn't turn on but bottom screen flashes white!
So a few days ago my DS was sitting on my bedside table which is 50cm from the floor, it was charging and my clumsy self tripped over the charger cable and the DS fell to the ground
The next day I went onto the DS I tried to turn it on, the blue light appeared and then suddenly it makes pop sound and the bottom white screen flashed and then it turned off.
Can anyone tell me what to do? I've heard it may be a problem with the ribbon cable but I'm not sure, I'd appreciate any kind of help 😊
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
That pop sound is usually from a damaged or unseated cable. It could be any of the connectors on the board, but usually its the display. You can try opening it up to check the connections, but if those connections are good, then it could be damaged displays which can also cause popping.
I would also double check that the unit can charge (Shows charging light) and that the connector on the board is solid.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Nix_Pix さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 56
