メインコンテンツにスキップ
ビデオ出力付きのPC用ディスプレイ(もしくはモニター)の修理ガイド
20回答 すべてを表示
AOC 24G2SP Monitor Colored horizontal lines across the screen
It was just a hairline and now it is getting progressively worse.
What is the cause for this?
I have already contacted AOC support for RMA this monitor has not gone through a year yet.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
ベストアンサー
Hi @glenedannl20817
Horizontal lines are mostly caused by failed gate drivers in the LCD panel.
You could check the ribbon cable connection that connect to the boards from the screen. As these cables are bonded to the screen sometimes they lift off so you could try apply a bit of pressure to the ribbon cable where the lines are to see if it changes or not.
If the line doesn't change then it is a problem in the panel itself.
As the monitor is still under warranty, I suggest that you do not open it to find out as this will void the manufacturer's warranty.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Thank you soo much for the comprehensive answer.
さんによる
コメントを追加
Hello,
Same problem here but with a MSI G271 monitor. Mine is not in warranty so, how could I fix it?
Thank you
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Glen Edann Leopoldo さん、ありがとうございました!
統計データ:
過去 24時間: 10
過去 7 日: 69
過去 30 日: 260
今までの合計 3,964
