メインコンテンツにスキップ
Repair guides and information for portable, battery powered Bluetooth speakers
108回答 すべてを表示
replace USB C port & charger port on my Anker soundcore motion boom pl
I haven't been able to listen to my speaker anymore because my charger port got pushed in and then the alternate charge port, the. USB c got super loose and no. Longer takes a charge either how how I replace them?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hi @katheriner25229
Here's a teardown video of the speaker that may help.
It shows how to disassemble the speaker so that you can check what needs to be done to fix the charge port and the USB-C connector e.g. they may simply be loose and need to be resoldered back on again, they're faulty and need to be replaced or if there's associated damage that needs repairing as well etc.
If there's damage or you're not quite sure, post some images showing what's happened to them, back here in your question. Here's how to do this on ifixit iFixitでの質問に画像を追加する方法
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Katherine Rose Williams さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 10
過去 30 日: 33
今までの合計 49
