メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
The Kenmore 110 Series is an easy to use home Washing machine created by Kenmore.
Machine Agitates but won't spin
the machine will not spin but agitates and drains. I changed the coupler and the clutch but it still won't spin. The motor runs and I can hear the change when I change speeds but the tub will not spin. Also, the tub is very hard to spin manually. Is this the transmission or the tub causing this?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
6 件のコメント
Hi @njbob,
What is the model number of the washer?
さんによる
Hi - it is 110.20952992
さんによる
@njbob
Can you manually rotate the tub in both directions or only the one way?
さんによる
I can spin it both directions - tight but it moves
さんによる
@njbob
Check the agitator dogs are OK.
They prevent the agitator from rotating in both directions as it should only rotate in the one direction
さんによる
1以上のコメントを表示
コメントを追加
1 件の回答
最も参考になった回答
Hi @njbob
Usually with spinning issues it's either the coupling, the clutch or the dogs
Since you have replaced the first two and you say that the dogs are destroyed and need replacement, that's most probably the reason for the problem.
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
Okay so even though the bottom of the agitator works it could still be the dogs that prevent the unit from spinning and when I say spinning I mean the spin cycle...?
さんによる
@njbob
Apologies. My mistake, got it mixed up with the top of the agitator not moving - brain fade ;-(
Seems as though it will be a transmission problem then, spin cam in gear box perhaps.
Here's a video that may help if you want to try and repair it.
Here's a link that has a video and also the manufacturer's part number 3360629 (examples only) that shows how to replace the transmission if you want to replace it instead
さんによる
Thanks so much. I'm bidding on a new trans so we'll see if I get it. Otherwise it's off to Home Depot for a new washing machine.
さんによる
コメントを追加
回答を追加する
njbob さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 7
今までの合計 181
