water log back camera how to remove clean without breaking glass cover
how do I remove and clean without breaking glass covering.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
@raulmorris since iFixit does not yet have a guide for this, Use something like the one from here It is written in French so use a browser that can translate it. You will need a good heat source to loosen the adhesive for the rear caver. Remember to reapply heat often to ensure that the adhesive stays soft. that is the trickiest part of this repair. Anytime you feel resistance when opening it, reheat.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 2
過去 30 日: 3
今までの合計 41
2 件のコメント
@raulmorris are you referring to just removing the cameras or are you wondering about how to deal with the water damage? What happened to your phone? Give us more details.
oldturkey03 さんによる
removing the cameras... the is water inside the cameras
Raul Morris さんによる
