There's a Scratch on TV
Is it possible to get rid of the scratch on the tv screen?
@thomasthombre if you are referring to the glass on the front of the TV then the answer is: Not likely. It is part of the TV. Now, depending on the scratch etc. some people have had some decent results by using a toothbrush and baking soda (or even toothpaste) and use that to "polish the scratch out. Again, this will all depend on how dep/wide/ the scratch is. Even so the scratch may appear less, it will most likely all be somewhat visible when the TV is on.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 2
過去 30 日: 10
今までの合計 75
