メインコンテンツにスキップ
The Samsung B1445A is a front-loading high efficiency washing machine by Samsung.
16回答 すべてを表示
Washing machine door won't unlock?
My washing machine cycle came to an end. After 3 minutes it is supposed to unlock, but it didnt. It has drained all the water out, so that's not a problem. I turned the power off on the wall, and it still wouldnt unlock. How can I get my wet washing out?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 18
13 件のコメント
My washer door seems to be stuck shut because an object is blocking it from inside.
さんによる
OK. I solved my own problem. There was a piece of clothing caught in the door. I push on the door and restarted the machine and discovered there was a piece of wash stuck in the door. I found this out by watching as I pushed. I started the machine twice and tried dislodge it and luckily I was able to before I burned out anything.
さんによる
Machine has stopped washing my clothes while there is water and clothes inside, now got a lock key which is not removable and I press all buttons nothing helpful at the moment, what to do in this case.
さんによる
My washer door wouldn't open after a spin cycle. We had to change the cycle and then it allowed us to open it but the barrel had water in it and the clothes were not spun dry
さんによる
* i have Samsung washing machine the red key light on so i cant open the door at the end of circle, when i unplug the electrical plug the door open .i try to load it again there is alot of water pumped from the drain and the light sill on the machine not working .
さんによる
8件以上のコメントを表示
コメントを追加
2件の回答
ベストアンサー
Jo11, this is a tricky washer. I suppose you did not get any error code to pinpoint it to the interlock mechanism or anything. You can try and open the door on the bottom right on the front of the machine. You will find a small black hose with a plastic plug in the end of it. It pulls out about 6in and you can use a pan. Sometimes a foreign object may prevent your drum from totally emptying, try something like a Shopvac to either suction it or to blow through it toward the drum to loosen things like missing socks ;-) etc.... I attached an image of the locking mechanism from the service manual for your own evaluation
このアンサーは役に立ちましたか?
スコア 8
16 件のコメント:
Thanks for your response. I managed to remove the top of the washer and saw that the interlock had burnt out and melted, therefore preventing the door from unlocking. After breaking the interlock off, I was able to access my washing. I have now ordered a new interlock and hope that it will be ok...but still not sure why it burnt out in the first place.
さんによる
Having looked through some of the forums, it appears that door does give a lot of people trouble. As for the burn out, it may have simple been from loose contacts or shaved insulation. You can download the service manual for a limited time from here Hope this helps.
さんによる
Thanks for the service manual...very useful! Its a wonder why its not included with the product when you buy it! Hopefully it was just loose contacts...will post an update once I have fit the new interlock!
さんによる
you are welcome. If they would include the service manual, some customer could fix their own appliances. This would mean less money for the manufacturer ;) I guess this is one of the reasons why ifixit is such a great place. Read the mission on here Do-It-Yourself Repair
さんによる
I agree! Thanks for that! I fit the new interlock and it all works fine now :)
さんによる
11件以上のコメントを表示
コメントを追加
最も参考になった回答
I've had this issue a couple of times. Both fixes were to run on "Spin Only" -- for some reason the washing machine didn't fully drain and only choosing "Spin Only" seemed to force the machine to fully drain.
このアンサーは役に立ちましたか?
スコア 10
13 件のコメント:
Thank you so much for this idea. I got my toolbox out and was about to try and "fix" the machine. I ran the spin only option and the door unlocked in a few seconds, before the cycle even completed. Immensely helpful idea.
さんによる
This solved my problem with no muss, no fuss. Who knows how much time, energy and money you may have saved me with your simple solution? Thank you!
さんによる
Thank you very much for the idea of using "spin" . It was very helpful !!
さんによる
Thank you so much. I was stressed trying figure where I'd the find the money to "fix" my issue. This worked Thank you
さんによる
thank you on spin cycle did the trick. it unlocked itself
さんによる
8件以上のコメントを表示
コメントを追加
回答を追加する
Jo11 さん、ありがとうございました!
統計データ:
過去 24時間: 21
過去 7 日: 126
過去 30 日: 593
今までの合計 395,682
