メインコンテンツにスキップ
Macハードウェアー言い換えるとAppleによって製造され外付けドライブや電源アダプター、ケーブル、コンバーターを含む Appleの製品にプラグインされるものです。
1112回答 すべてを表示
Why won't Battery door will not open on Apple Remote Model No A1156?
Would like to replace the battery in my Apple Remote. No matter what I try, the push/release mechanism will not release the battery tray. Any way to get this door open without damaging the device?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
3件の回答
最も参考になった回答
need to get a paper clip or sort, and push down into the little hole and it flips open, to replace battery. battery type is a Panasonic CR2032 3V
Good luck
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
I use the jack of my headphones, pushing it all the way down. It's thin enough, and sturdy, and doesn't scratch the button as a paper clip could do if you've got jittery hands.
さんによる
This worked. You have to push harder than you would think.
さんによる
コメントを追加
This seems to work only with the new "silver" remotes. I cannot find any way to open the original White ones. Does anyone have information on disassembling the white A1156 EMC 2086 models?
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Stefano's tip worked for my white A1156 EMC 2086 models
さんによる
Ok Steve, I too, have the identical remote... and had trouble opening it. After reading the above comments, let me just confirm that you need to use a semi pointed object to press in the small round circle located on the bottom of the remote.... I used a standard size nail (as in hammer) and finally the battery tray popped loose. Note that the circle will be hollow when popped out... If somehow, the remote became sticky and the spring mechanism is gummed up, do what you need to do... like place the bottom one inch (1") in hot water being carful not to submerge the button area into the water... this should free up the geewie stuff freezing the spring loaded tray. Good Luck
さんによる
コメントを追加
In case anyone still needs an answer to this question here is the link to Apple Support answering this question. http://support.apple.com/kb/HT1306
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Steve Mattson さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 4,629
