Samsung Galaxy M32 5g Someone else's Samsung Account Sign Out How do i
Samsung Galaxy M32 5g Someone else's Samsung Account Sign Out How do to it
If you are trying to use this phone with someone else's account, you'll have to perform a data reset to delete everything to restore it back to factory new-like condition. If a sim card is installed, remove it before resetting. Some Samsungs have a tiny hole on one side for a factory supplied pin to insert to force erasure of all data. A small blunt needle will suffice, Once data is deleted, insert your sim card to begin configuring this phone to your cellular carrier to register it.
このアンサーは役に立ちましたか?
Before you perform a data reset be sure to remove the google account first or it will ask you for it again it during setup, this is google's FRP lock.
Remove a Google or other account from your phone
Open your device's Settings app.
Tap Passwords & accounts. ...
Under "Accounts," tap the account you want to remove. ...
To confirm, tap Remove account. ...
If this is the only Google Account on the device, you'll need to enter your device's pattern, PIN, or password for security.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 6
今までの合計 33
