Why does my neon stop running above 70 degrees
Anytime the temperature reachs 65 or higher my car seems to overheat. After 15 minutes it runs again til it heats up. I have changed the thermostat and had the radiator flushed twice has not solved the problem. When it heats up from a stop it hesitates and almost kills then runs rough
この質問は役に立ちましたか?
1件のコメント
Matt, does your fan work properly? Do you have the service engine light on? Have you checked for any error codes? How many miles on your Neon, and what engine and type of transmission does it have?
oldturkey03 さんによる
