メインコンテンツにスキップ
Mid 2006 / Model Number: A1181 / black or white case / 1.83 or 2.0 GHz Intel Core Duo processor
418回答 すべてを表示
Why won't my mouse button click?
The mouse button (not the whole trackpad, or the keyboard, but just the mouse button) has decided that it's permanently depressed, which means I can't click on anything anymore. It's definitely a hardware issue; the same thing continues if I boot into Ubuntu.
The computer's too old to merit the couple hundred dollars it would take to replace the whole upper case, so I wanted to see if anyone had any other ideas about how to fix this. Is there a connector somewhere that could have gotten loose? Is there something I can try to clean? Etc.
Wild ideas welcome.
Thanks!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
ベストアンサー
Well, the trackpad assembly is fully immersed and melted in the topcase, so there's no way you could act in it.
You can try using a piece of paper or something thin enough and move between the button and the trackpad, to see of something got lodged that.
Or try the topcase without the battery: a chinese battery I have presses on the topcase for example, making the button "sturdier" at touch. If without battery the button works fine, that means the battery is pushing on the mechanism.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
bdhamilton さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 2
今までの合計 2,267
