When I turn on the pc, the fan is on but pc isn't booting up.
When I turn on the pc, the fan is on but pc isn't booting up. keeps making sounds with the fan
@benancyber besides the fan, what have you checked? Start with the basics of your troubleshooting.
Download the service manual for your computer from here Start with the troubleshooting on page 260. Let us know what you find out.
このアンサーは役に立ちましたか?
@oldturkey03 still not working coz i had already done all
Hi @benancyber
Not sure when you say "done all" whether this included a full power refresh by disconnecting the power to the PSU and then accessing the motherboard to remove the RTC coin cell battery from the motherboard and then holding the Power button operated for 30 seconds?
If not try doing that. When the RTC coin cell battery is removed, measure its voltage. If it is <2.5V DC or the battery is >4-5 years old, replace it. The battery type is stamped on the battery itself. Usually they are CR2032 or CR2026 which are available everywhere e.g. supermarkets
Remember to reinsert the RTC battery (+ve on top as marked on the battery) and then reconnect the power to the PSU and turn it on and check if it starts OK.
このアンサーは役に立ちましたか?
過去 24時間: 3
過去 7 日: 9
過去 30 日: 37
今までの合計 138
