メインコンテンツにスキップ
Samsung Galaxy S21 FE (Fan Edition) is a variant of the S21 model and was released on January 11th 2022. The phone has a few changes from the main S21 model, making it slightly cheaper.
30回答 すべてを表示
My phone's bluetooth connects to any speaker but no sound comes out
My phone used to connect to speakers via bluetooth with no problem but since the beginning of this year it now it connects to a speaker but no sound comes out. And it's not the speakers because I have successfully connected different phones/devices to the speakers and the sound is just fine. The issue only seems to be related to my phone. Has anyone ever experienced anything similar to this or have any suggestions on what I can do to fix this?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
4件の回答
From past experiences, try restarting the phone and BT sound device, then pair them and try again. If that doesn't work, in your phone settings, in Bluetooth, remove (or "Forget") that BT device, then re-pair the device. If that doesn't work, your phone's BT chip may be at fault.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I've already tried both of those but that has not resolved the issue I also reset the network settings but the issue remains
さんによる
コメントを追加
This is a hardware issues, beacuse of low quality components used in the device. Try bending the device left or right in the top part, while something is playing in the background via Bluetooth. Unfort this will cost you more probably a motherboard change!
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I'll have to try and see if that works , if so looks I'll just have to get a new phone 😩
Update: thank you, this actually got it to work but I'm sure it's just a temporary fix. If I were to drop it or it gets knocked around it'll probably go back to not working.
さんによる
コメントを追加
I got this very same issue and I don't wanna open the phone because I don't know which part would I need to repair, did you find an fix?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Unfortunately, no I haven’t
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Shawniece さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 10
過去 30 日: 91
今までの合計 392
