screen isn't turning on after replacement
wont turn on after screen replacement
Is the original screen still in a sort of working condition so that you reinstall it to check if the problem is due to the replacement display or on the systemboard?
If not, it may come down to board level testing using the service manual to find out what's wrong.
I couldn't find a free download online, you may have better luck.
このアンサーは役に立ちましたか?
Hi @michelle51666,
See Step.51 of the ifixit Samsung Galaxy S22 スクリーンとバッテリーアセンブリの交換 guide
過去 24時間: 0
過去 7 日: 2
過去 30 日: 6
今までの合計 64
Hi @michelle51666,
Have you checked if the display flex cable is securely connected?
jayeff さんによる
sm 901 and I had it all apart and put it back together everything seems in place an tight
michelle さんによる
i think so im no pro at all tbh i have no idea what im doing i watched alot of youtube so idk if i even know which flex cable that is
michelle さんによる
