Why is my phone doesn't vibrate when ringing?
My phone has stopped vibrating by its own when people call
To make your TECNO Spark 6 Air vibrate, you can use the “Vibrate on touch” setting in the “Sound & vibration” menu of the “Settings” app on your phone. Here's how to do it: To make your TECNO Spark 6 Air vibrate, you can use the “Vibrate on touch” setting in the “Sound & vibration” menu of the “Settings” app on your phone. Here's how to do it: Open the “Settings” app on your phone. Scroll down and tap "Sound & vibration." Scroll down and tap "Vibrate on touch." Turn on the “Vibrate on touch” toggle switch. Test the vibration function by tapping the screen or pressing a button on your TECNO Spark 6 Air. Your phone will vibrate.
このアンサーは役に立ちましたか?
Verify that the "Silent Mode" is off: If your phone has a "Ring switch", move the switch forwards so that the orange bar is hidden. You can also use "Control Center" to check if the "Silent Mode" is turned on.
このアンサーは役に立ちましたか?
First check the settings, if setting are okay then maybe you need to change the vibrator.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 5
過去 30 日: 21
今までの合計 1,072
