メインコンテンツにスキップ
A larger version of the P-series. Repair will require screwdrivers and some tool for prying areas open. Comes in Red and Black versions.
24回答 すべてを表示
I can't see the pictures in the sd card. Nikon Coolpix p510
I take the pictures and insert the SD card into the computer, but I cannot see the pictures in the computer. When I scan the SD card with data recovery programs, I can see the images. What could be the reason for this?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
Just reading the User Guide, this camera is capable of taking special 3D images, of two separate (left and right ) images, and saving the file as .MPO file type.
The fact that you can see the images with the data recovery program on your computer is encouraging.
IF by chance you are accidentally taking 3D pictures, you will not see them on your computer without a special provisioned 3D compatible monitor;
It is certainly possible your computers photo management application may not be compatible with the image file type the camera is taking.
Do you know for certain the images are being saved as
.jpg files?
What type of computer (Windows?, iMac ? Ubuntu?..._) are you using?
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Before i start im sorry for my bad english. I use windows 10. All the pictures I saved from the data recovery program are in .jpg picture format and I can open them and see them, but without data recovery programs (for example, stellar data recovery, EaseUs) I can't see them in Windows 10. I could see my pictures before the problem. I have been experiencing this problem for the last 2 months and it is very annoying. Thank you!
さんによる
コメントを追加
回答を追加する
ilkinsm さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 7
今までの合計 43
