メインコンテンツにスキップ
モデル番号 A1367/ 8, 16, 32 もしくは64 GB容量
913回答 すべてを表示
How do I reset a disabled iPod Touch without a computer?
My iPod Touch 4th Gen will not enable. I forgot the password. How do I reset it without a computer?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 316
68 件のコメント
Hold down power and home button until logo shows up and will reset to factory downside is all data will be deleted
さんによる
I don't have a computer
さんによる
さんによる
You can't do it without a computer
さんによる
i have ipod 5 touch does it work on this
さんによる
63件以上のコメントを表示
コメントを追加
17件の回答
ベストアンサー
There is no way to do that, unfortunately. You have to put the iPod into DFU mode and then use a computer to restore it. I would suggest trying to find a buddy who will let you use their computer. To DFU the iPod, have it plugged into the computer, hold the lock and home buttons until the device shuts off, wait five seconds, and then release the lock button while still holding the home button. A message should then pop up on the computer telling you that the iPod is in recovery mode and that you have to restore it. Let me know if you have any questions
このアンサーは役に立ちましたか?
スコア 76
56 件のコメント:
this didn't hepl tell me an alternative method if possible
さんによる
@abhisek neymar, just like Jason rightly answered, there is no alternative method. "There is no way to do that unfortunately. You have to put it into DFU mode and then use a computer to restore it." Follow his advise .
さんによる
What happens if that does not shut it off
さんによる
This happened to mine. I did exactly what he said and it is restoring as I am typing. Thank you so much! This helped and I can't wait even tho it will take an hour or so thanks so much!!(:
さんによる
what if a message pops up saying there's an error occurred (3194) ???????????
さんによる
51件以上のコメントを表示
コメントを追加
Requirements :
1. A computer (Mac or Windows)
2. An Apple USB Cable
3. Your iPod
Method:
1. Connect your iPod to a computer running iTunes using the USB cable
2. Make sure your iPod is turned on, the hold both the Home and lock buttons simultaneously and hold for 10 seconds
3.On your computer go to iTunes and click "Restore iPod"
4. Wait for iPod to restore and enjoy!
Hope this helps
このアンサーは役に立ちましたか?
スコア 14
13 件のコメント:
I get a message that I have to restore the ipod before using it with itunes but when I click ok, the restore ipod screen goes away. How can I keep that screen up to restore it?
さんによる
If i restore my ipod touch 4 will it delete my apps, music, pictures, etc
さんによる
What if u don't have an apple account how do we do it then it will not let me I try using my aunts account and it will not let me
さんによる
but windows doesnt recognize my ipad it keep saying usb not recognize
さんによる
What if you have a chrome Book and not able to connect to iTunes i would ask my mom but she would say no so what do i do??
さんによる
8件以上のコメントを表示
コメントを追加
all you have to do is hold the power button and home button at the same time for ten seconds then let go of the power button but keep holding on to the power button for 10 seconds. then it should restart.
このアンサーは役に立ちましたか?
スコア 8
4 件のコメント:
i tried that before but when i did it still popped up saying iPod is disabled connect to itunes
さんによる
it is not working
さんによる
Let go of the power button but hold the power button on? That does not make sense
さんによる
I know right
さんによる
コメントを追加
If you don't have one then you'll need to buy or get a lend of one I'm sure you no someone with a USB cable
このアンサーは役に立ちましたか?
スコア 6
1件のコメント:
Would iMac,MacBook include a usb cable
さんによる
コメントを追加
I don't have a computer and I forgot my password and the people I do know don't have a computer
このアンサーは役に立ちましたか?
スコア 5
3 件のコメント:
As I stated before you need a computer to complete this process. Try your local library, apple store or best buy.
さんによる
wow "the people i DO know" makes it sound like you live in a cave and the only people you DO know are the ones who you haven't eaten yet.
さんによる
verizon stores will unlock or reset your ipod for free! u dont need a verizon account!
さんによる
コメントを追加
yes unfortunately you cant do anything without the computer i tried everything and still does not work. my charge bars are bent so it does not work i will try suggestions if any one has some very appreciative
このアンサーは役に立ちましたか?
スコア 4
1件のコメント:
verizon stores will unlock or reset your ipod 4 u for free, u dont have to even have a verizon account
さんによる
コメントを追加
Well basiclly you press the sleep wake button and home button for 10 secs till Apple icon appears. Then let go of the buttons. Hope this helps!
このアンサーは役に立ちましたか?
スコア 3
3 件のコメント:
that didnt help at all i tried a couple of times but it didnt work ):
さんによる
i found an ipod touch 2nd generation its has a password and i need help unlocking it.how do i do that without a computer
さんによる
Close, you need to continue to hold the home button after 10 seconds and releasing the lock button. That is the difference between a forced reset and putting it into DFU mode. Alisha first off you should contact Apple and try to return the iPod. I am sure someone is missing it
さんによる
コメントを追加
i found a ipod touch, but ican't to delete the id and password.
このアンサーは役に立ちましたか?
スコア 3
1件のコメント:
Take it to Verizon they will unloOk or reset it 4 free, NO verizon account needed, takes 10 min
さんによる
コメントを追加
Can I plug into another phone using iTunes app then do the reset function? ?? Would that work
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
Can someone help me unlock my iPod touch 5 i got it on letgo serial number is dj6kt0cff4k4 can someone help me out
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
IPod 5 no enciende que se le hace
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
well you get your usb cable and hook it up to an outlet than you take a pic then you will go tot he lockscreen and slide up so on the left hand side you will see a flash light Image than right next to it on the right there is like a watch images than you will click on that then you press the sleep/awake button then it will say slide to sut off under that it will say cancel you pres on cancel then you wil press the home button 2 times really face hope this work cause it worked on mined
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
What?Wheres the correct spelling?
さんによる
i've erased my ipod, version: 421(8c148) model:MB52LL
さんによる
Apple iPod 7.0.4. Serial number-ccqm345gffcj. Says connect to itunes
さんによる
コメントを追加
If you don't have a computer then go to the Apple store, and use one if those. They will let you use it.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
how do i reset a ipod if it wont go into dfu mod it just shows the apple logo
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Get my ipod said disabled CONNECT itunes how get off please help me
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
I know how you feel, my dad will recover it, but try to find a nearest Apple store, or use your teachers MacBook or iMac! Hope it helps! I’m in 5th grade so this should help! :)
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Apple store will let you borrow computer
さんによる
コメントを追加
How do I unlock my ipod without a computer
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
kato さん、ありがとうございました!
統計データ:
過去 24時間: 4
過去 7 日: 25
過去 30 日: 98
今までの合計 484,228
