メインコンテンツにスキップ
The Xiaomi Poco X3 Pro is an entry level smartphone by Xiaomi released March 2021. It is equipped with a 6.67" IPS LCD screen, a 48 MP main camera and runs on the Qualcomm Snapdragon 860.
90回答 すべてを表示
The charge light is flashing, and the phone isn't turning on.
I watched a YouTube video on this problem and learnt a few troubleshooting techniques. When I tested for the voltage of the battery it was 3.4V which is lower than it should be, meaning it needs to be boosted. However when I test how much voltage is going to the battery, I get 1.8V. This is different from the 5.6V which is entering through the flex motherboard cable from the charging port. Any ideas that could help?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
@leeky39051 you want to post some good pictures of your boards and show us where you measured those voltages. In the meantime, here is the schematics for the charging circuit. you can measure to check if those components are having any issues.
iFixitでの質問に画像を追加する方法
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
leeky さん、ありがとうございました!
統計データ:
過去 24時間: 4
過去 7 日: 10
過去 30 日: 54
今までの合計 208
