Your PC ran into a problem and need restart,we'll restart for u
My desktop while booting shows same green screen message (Your PC ran into a problem and need restart,we'll restart for u)and this happening in loop how to fixx this?
Accessing Advanced Start-up when PC isn't loading:
If your device isn't loading or stuck during boot, you can use this method to access the recovery environment:
After the third interruption, Windows 10 / 11 will open into the Advanced Start-up environment
· While in the Advanced start-up environment, use the following steps to use Start-up Repair:
If the above doesn’t help do the same as above but this time select “System Restore” from the “Advanced Options?”
Run following:
SFC /scannow
(Note: Repair Windows 10 - "you need to sign in as an administrator to continue, but there aren't any administrator accounts on this PC"
Enable F8 key for booting into Safe Mode from CMD
bcdedit /set {default} bootmenupolicy legacy v
このアンサーは役に立ちましたか?
Can i do the same procedure in windows 11?
Have you tried it yet?
過去 24時間: 1
過去 7 日: 2
過去 30 日: 7
今までの合計 101
