What I should do my earphone jack in mobile doesn't work
When I put earphone in mobile jack it doesn't work I tried many times but it isn't.
Do you get the earphone icon being displayed on the screen when you plug the earphones in?
When playing audio does the loudspeaker turn off when you plug the earphones in?
If the answers to the above are no (or even yes) it may be a faulty earphone jack. If it is faulty it cannot be repaired, it has to be replaced.
Fortunately this is relatively easy to do as the earphone jack is part of the charge port board module.
Here's a video that shows how to replace the charge port board in the phone. You can see it being removed from 2:44 minutes into the video.
Search online for Samsung Galaxy A14 5G (SM-A146B) USB charging board to find suppliers that suit you best.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 130
