メインコンテンツにスキップ
The LG Stylo 4 is a stylus-equipped midrange slate-format Android smartphone released by LG in 2018. Identifiable by model numbers L713DL and Q710(AL, CS, MS, TS, ULM, ULS, and US).
23回答 すべてを表示
Why wont my LG stylo 4 Charge
everytime i try to charge my lg stylo 4 it stays on 1% and i cant turn it on, when i try to power it on while its charging it looks like it boots up but when it fully turns on it says battery empty powering off. Ive no idea whats going on
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
@kingofspades the very first thing you want to do is to replace your battery. Since ifixit does not yet have a guide for that, use something like this video Batteries are readily available at plenty of online stores. Just make sure you get the one for your version.
If a new battery does not accomplish this, replace the charging flex as well. Use something like this video for that. The flex is readily available at places like this (example ony) and many others.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Ok thanks for commenting!
さんによる
コメントを追加
回答を追加する
King0fSpades05 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 3
今までの合計 39
