メインコンテンツにスキップ
The Samsung Galaxy A10s is an Android smartphone developed by Samsung Electronics, and was released in March of 2019.
126回答 すべてを表示
A10s network cable jumper
Network cable jumper
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
I’m sorry to hear that your Samsung Galaxy A10s network cable jumper is not working. This could be due to various reasons, such as a faulty cable, a damaged network IC, or a loose connection. Here are some possible solutions that you can try:
  • You can watch some videos that show how to fix the network cable jumper problem on Samsung A10s. For example, you can check out these videos: Samsung A10s Network Problem or samsung a10s network problem ll samsung a10s network wire jumper ll galaxy a10s network problem. They demonstrate how to use a soldering iron and a multimeter to repair the network cable jumper and restore the signal.
  • You can also try to reset your network settings on your phone. This might help if the problem is caused by some software issues or incorrect configurations. To do this, please go to settings > general management > reset > reset network settings1. Then, restart your phone and see if the network works.
  • If none of the above solutions work, you might need to replace the network cable jumper or the network IC on your phone. This might require professional assistance, as it involves opening the phone and replacing the components. You can contact Samsung customer service or visit a nearby authorized service center for help.
I hope this helps you fix your Samsung Galaxy A10s network cable jumper problem. If you have any other questions, please feel free to ask me. 😊
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Dije さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 11
今までの合計 75
