Why doesn't my phone want to charge and why is there a question mark?
A question mark appearing when trying to charge the phone, usually indicates that the battery is not being detected in the phone. Loose battery cable connection or more likely a failed battery.
Here's a video that shows how to replace the battery in the phone that may help.
Rather than using a heat pad to warm up the adhesive that is holding the battery in situ, as shown in the video, it may be better to use a syringe filled with Isopropyl Alcohol 99%+ to loosen it as shown in this video for a nearly similar phone.
Search online for SLC-50 battery to find battery suppliers that suit you best.
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 2
過去 30 日: 2
今までの合計 55
