メインコンテンツにスキップ
The Infinix Hot 10i is an entry level smartphone with a 6.52 screen and a 6000 mAh battery released May, 2021.
59回答 すべてを表示
Fingerprint sensor not showing on my phone
I can't find fingerprint sensor on my phone
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 8
コメントを追加
3件の回答
ベストアンサー
@emperorvibez first try to reboot your Infinix to check if your fingerprint sensor is working. IF that does not work you want to check your and update your software. Go to Settings==>About Phone==>System Update and let your phone check for any updates. If there are any, those should show up as Download Update. Use those to download and update your Infinix.
You can still clear your cache and other thing if the above did not work. Check sites like this one for how to clear your caches etc.
If none of that worked, you may have an actual hardware issue, like a failed fingerprint sensor. Since iFixit does not yet have a guide for that, try something like this video It is not the identical model but it will work for yours as well.
A replacement sensor is readily available at many online stores. Purchase one from a vendor to your liking, just make sure you purchase a fingerprint sensor for your exact model.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
  1. Navigate to Settings.
  2. Look up "System" using the search box and click on it.
  3. Choose Reset options.
  4. Reset Bluetooth, Wi-Fi, and mobile devices > Reset settings.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Finger lock show
My phone finger lock not show
What is the problem
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
@kokokhan have you tried the solutions in the original answer? What did you try?
さんによる
コメントを追加
回答を追加する
Emperor Vibez さん、ありがとうございました!
統計データ:
過去 24時間: 24
過去 7 日: 210
過去 30 日: 882
今までの合計 3,234
