メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Appleの第7世代iPadの修理と分解ガイド情報です。
doesn't turn on.
it was about a year ago when it stopped charging with its original charger, i then tried mac's charger to charge it. but it also didn't work, it was charging but very slowly and suddenly went dead since then.
i send it to local repair shop and they said probably it is motherboard issue and can't be solved. can you suggest me what to do?!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
I know it's a fairly common issue for the CPU to die on the 7 series and it's just not worth fixing.
You could reach out to a board repair specialist to see what they have to say. If you're out of the US, I believe iPad Rehab might be able to accept the repair. If you're in the US, both iPad Rehab and VCC Board Repairs could take a look at it. I've personally taken Rehab's board repair course and I send my data recovery jobs to Jesse at VCC. Good luck!
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Omor Seebtaien さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 10
今までの合計 98
