メインコンテンツにスキップ
Mid 2006 / Model Number: A1181 / black or white case / 1.83 or 2.0 GHz Intel Core Duo processor
418回答 すべてを表示
Why wont my lcd screen stay powered?
I recently got my computer put back together after a long while of sitting on my desk collecting dust. It starts up and everything but backlight is not lighting up. When i hit the power button it does the regular startup the beeeeeem, the gray screen comes up and the backlights on for a second then the backlight turns off but the apple stays on.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
2件の回答
ベストアンサー
Well, it could be the Inverter, the cable from logic board to inverter, the LCD backlight or, in a percentage so negligibile that I'd not even count that possible, the capacitor on the Logic Board that fuels the Inverter.
Were you, I'd try with a fresh inverter. If that doesn't work, with a new inverter cable. Failing that, a new LCD panel.
I've got a Macbook 13'' myself whose backlight is slightly acting up, and I plan to fix it among some other "old age issues". They told me about desoldering the CCFL lamp and putting a new one, but that's a difficoult operation, so many people just swap a fresh LCD panel.
But as the LCD is the most costly part of the trio, you should first try with the inexpensive "Inverter + Inverter Cable" combo. Works 95% of the time.
It also would be useful if you gave us the last four letters of the Serial number, to gauge which model is the machine.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
My Macbook (AZ64) will turn on normal then the backlight go out. I close the Macbook and open again I hear the DVD kick in and he backlight come on right after for 2 seconds then turn off by itself. This happens every time I open the Macbook. Should I just try to replace the Inverter + Inverter cable to solve the problem? Please help.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Already answered in your question. The Inverter is a safe bet.
さんによる
コメントを追加
回答を追加する
OgCorndogg さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 726
